A novel SOM-based approach for active contour modeling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
In this paper, we integrate the advantages of SOM- and snake-based ACMs in order to extract the desired contour from images. We employ: (i) the feature points to guide the contour, as in the case of SOM-based ACMs; (ii) the gradient and intensity variations in a local region to control the contour movement. However, in contrast with the snake-based ACMs, we do not use an explicit energy functional based on gradient or intensity. The algorithm is tested on synthetic binary and gray-level images, and the results show the superiority of the proposed algorithm over other conventional SOM- and snake-based ACM algorithms.
Fichier non déposé
inria-00590182 , version 1 (03-05-2011)
Yedatore-Venkatakrishnaiya Venkatesh, S.Kumar Raja, Ramya Narasimha. A novel SOM-based approach for active contour modeling. Intelligent Sensors, Sensor Networks and Information (ISSNIP '04), Dec 2004, Melbourne, Australia. pp.229--234, ⟨10.1109/ISSNIP.2004.1417467⟩. ⟨inria-00590182⟩
10 Consultations
0 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
