Web information management with access control - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Alban Galland
  • Fonction : Auteur
  • PersonId : 864369
Serge Abiteboul
Neoklis Polyzotis
  • Fonction : Auteur
  • PersonId : 882721
We investigate the problem of sharing private information on the Web, where the information is hosted on different machines that may use different access control and distribution schemes. We introduce a distributed knowledge-base model, termed WebdamExchange, that comprises logical statements for specifying data, access control, distribution and knowledge about other peers. The statements can be communicated, replicated, queried, and updated, while keeping track of time and provenance. This unified base allows applications to reason declaratively about what data is accessible, where it resides, and how to retrieve it securely.
WebDB11.pdf (279.72 Ko) Télécharger le fichier
inria-00595200 , version 1 (24-05-2011)
  • HAL Id : inria-00595200 , version 1
Alban Galland, Serge Abiteboul, Neoklis Polyzotis. Web information management with access control. 14th International Workshop on the Web and Databases (WebDB), Jun 2011, Athens, Greece. ⟨inria-00595200⟩
258 Consultations
126 Téléchargements
