Robot development: from components to systems - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2011
While the last twenty years have seen the development of numerous robot integration frameworks, the last years have seen some kind of a consolidation. The obvious suspect being ROS [11], with trailing behind Orocos/RTT [13], OpenRobots and OpenRTM-aist; there are also older frameworks like MCA [12], which seem to have stopped their development, but provided basic ideas the aforementioned systems. This is list by no means meant to be exhaustive, it just lists { from the point of view of the authors { what component layers are getting adopted in the community to date.
Joyeux-Rock.PDF (468.14 Ko) Télécharger le fichier
Dates and versions
inria-00599679 , version 1 (10-06-2011)
Identifiers
  • HAL Id : inria-00599679 , version 1
Cite
Sylvain Joyeux, Jan Albiez. Robot development: from components to systems. 6th National Conference on Control Architectures of Robots, INRIA Grenoble Rhône-Alpes, May 2011, Grenoble, France. 15 p. ⟨inria-00599679⟩
Collections
CAR-2011
607 View
602 Download
Share
