Optimum block replacement policy over a random time horizon - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Intelligent Manufacturing Année : 2011
Nidhal Rezg
  • Fonction : Auteur
  • PersonId : 9267
  • IdHAL : rezg
  • IdRef : 075082160
Daoud Ait-Kadi
  • Fonction : Auteur
In this paper we consider the block replacement policy (BRP) for a system operating over a random time horizon. Under such a policy, a system is replaced by a new one either at failure or at a given time interval. The optimality criterion is the expected total replacements cost. Conditions under which an optimal replacement period exits are given. It is shown that BRP over an infinite time horizon is obtained as a particular case of the present work. A numerical example is given to illustrate the proposed replacement model.
inria-00601411 , version 1 (17-06-2011)
Abdelhakim Khatab, Nidhal Rezg, Daoud Ait-Kadi. Optimum block replacement policy over a random time horizon. Journal of Intelligent Manufacturing, 2011, ⟨10.1007/s10845-009-0364-9⟩. ⟨inria-00601411⟩
117 Consultations
0 Téléchargements
