Visual attention using spiking neural maps - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Visual attention is a mechanism that biological systems have developed to reduce the large amount of visual information in order to efficiently perform tasks such as learning, recognition, tracking, etc. In this paper we describe a simple spiking neural network model that is able to detect, focus on and track a stimulus even in the presence of noise or distracters. Instead of using a regular rate-coding neuron model based on the continuum neural field theory (CNFT), we propose to use a time-based code by means of a network composed of leaky integrate-and-fire (LIF) neurons. The proposal is experimentally compared against the usual CNFT-based model.
Informatique
ijcnn_final_PID1818371.pdf (638.89 Ko) Télécharger le fichier
inria-00603929 , version 1 (27-06-2011)
  • HAL Id : inria-00603929 , version 1
Roberto A. Vazquez, Bernard Girau, Jean-Charles Quinton. Visual attention using spiking neural maps. International Joint Conference on Neural Networks IJCNN 2011, Ali Minai, Hava Siegelmann, Jul 2011, San José, United States. ⟨inria-00603929⟩
233 Consultations
236 Téléchargements
