Interactive Point-based Modeling of Complex Objects from Images - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
Modeling complex realistic objects is a difficult and time consuming process. Nevertheless, with improvements in rendering speed and quality, more and more applications require such realistic complex 3D objects. We present an interactive modeling system that extracts 3D objects from photographs. Our key contribution lies in the tight integration of a point-based representation and user interactivity, by introducing a set of interactive tools to guide reconstruction. 3D color points are a flexible and effective representation for very complex objects; adding, moving, or removing points is fast and simple, facilitating easy improvement of object quality. Because images and depths maps can be very rapidly generated from points, testing validity of point projections in several images is efficient and simple. These properties allow our system to rapidly generate a first approximate model, and allow the user to continuously and interactively guide the generation of points, both locally and globally. A set of interactive tools and optimizations are introduced to help the user improve the extracted objects.
Poulin-2003-IPM.pdf (4.09 Mo) Télécharger le fichier
PSDFD03.avi (44.36 Mo) Télécharger le fichier
Format : Figure, Image
Format : Autre
inria-00606741 , version 1 (22-07-2011)
  • HAL Id : inria-00606741 , version 1
Pierre Poulin, Marc Stamminger, Francois Duranleau, Marie-Claude Frasson, George Drettakis. Interactive Point-based Modeling of Complex Objects from Images. Proceedings of the 2003 Conference on Graphics Interface, Jun 2003, Halifax, Canada. pp.11-20. ⟨inria-00606741⟩
Collections
INRIA INRIA2
137 Consultations
89 Téléchargements
