Towards Scheduling Evolving Applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Most high-performance computing resource managers only allow applications to request a static allocation of resources. However, evolving applications have resource requirements which change (evolve) during their execution. Currently, such applications are forced to make an allocation based on their peak resource requirements, which leads to an inefficient resource usage. This paper studies whether it makes sense for resource managers to support evolving applications. It focuses on scheduling fully-predictably evolving applications on homogeneous resources, for which it proposes several algorithms and evaluates them based on simulations. Results show that resource usage and application response time can be significantly improved with short scheduling times.
main.good.pdf (131.37 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
inria-00609353 , version 1 (18-07-2011)
  • HAL Id : inria-00609353 , version 1
Cristian Klein, Christian Pérez. Towards Scheduling Evolving Applications. CoreGRID/ERCIM Workshop on Grids, Clouds and P2P Computing, Aug 2011, Bordeaux, France. ⟨inria-00609353⟩
158 Consultations
205 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
