Unique decomposition for a polynomial of low rank - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2011
Let $F$ be a homogeneous polynomial of degree $d$ in $m+1$ variables defined over an algebraically closed field of characteristic 0 and suppose that $F$ belongs to the $s$-th secant variety of the $d$-uple Veronese embedding of $\mathbb{P}^m$ into $ \PP {{m+d\choose d}-1}$ but that its minimal decomposition as a sum of $d$-th powers of linear forms requires more than $s$ addenda. We show that if $s\leq d$ then $F$ can be uniquely written as $F=M_1^d+\cdots + M_t^d+Q$, where $M_1, \ldots , M_t$ are linear forms with $t\leq (d-1)/2$, and $Q$ a binary form such that $Q=\sum_{i=1}^q l_i^{d-d_i}m_i$ with $l_i$'s linear forms and $m_i$'s forms of degree $d_i$ such that $\sum (d_i+1)=s-t$.
PO1.1_1.pdf (223.38 Ko) Télécharger le fichier
inria-00613049 , version 1 (02-08-2011)
  • HAL Id : inria-00613049 , version 1
Edoardo Ballico, Alessandra Bernardi. Unique decomposition for a polynomial of low rank. 2011. ⟨inria-00613049⟩
175 Consultations
120 Téléchargements
