Improved efficiency of spring embedders: taking advantage of GPU programming - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
This paper introduces an approach aimed at improving computation time for spring embedders in a context of graph visualization. The approach relies on recent developments in the utilization of graphic processor units (GPU) for generic numerical computation. We show how a GPU can greatly improve computation time, hence opening many previously unattainable possibilities in terms of interactive applications. Our method has been implemented in software used for benchmarks demonstrating large performance gain.
Fichier non déposé
inria-00614161 , version 1 (09-08-2011)
  • HAL Id : inria-00614161 , version 1
David Auber, Yves Chiricota. Improved efficiency of spring embedders: taking advantage of GPU programming. 7th IASTED International Conference on Visualization, Imaging and Image Processing, Aug 2007, Palma de Mallorca, Spain. pp.169-175. ⟨inria-00614161⟩
206 Consultations
0 Téléchargements
