Piecewise Affine Registration of Biological Images for Volume Reconstruction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Medical Image Analysis Année : 2006
This manuscript tackles the reconstruction of 3D volumes via mono-modal registration of series of 2D biological images (histological sections, autoradiographs, cryosections, etc.). The process of acquiring these images typically induces composite transformations that we model as a number of rigid or affine local transformations embedded in an elastic one. We propose a registration approach closely derived from this model. Given a pair of input images, we first compute a dense similarity field between them with a block matching algorithm. We use as a similarity measure an extension of the classical correlation coefficient that improves the consistency of the field. A hierarchical clustering algorithm then automatically partitions the field into a number of classes from which we extract independent pairs of sub-images. Our clustering algorithm relies on the Earth mover's distribution metric and is additionally guided by robust least-square estimation of the transformations associated with each cluster. Finally, the pairs of sub-images are, independently, affinely registered and a hybrid affine/non-linear interpolation scheme is used to compose the output registered image. We investigate the behavior of our approach on several batches of histological data and discuss its sensitivity to parameters and noise.
MedIA-WBIR-pitiot-etal.pdf (1.68 Mo) Télécharger le fichier
inria-00614996 , version 1 (17-08-2011)
  • HAL Id : inria-00614996 , version 1
Alain Pitiot, Eric Bardinet, Paul Thompson, Grégoire Malandain. Piecewise Affine Registration of Biological Images for Volume Reconstruction. Medical Image Analysis, 2006, 10 (3), pp.465--483. ⟨inria-00614996⟩
85 Consultations
565 Téléchargements
