Journal articles
Building, registrating and fusing noisy visual maps
Nicholas Ayache 1, * Olivier Faugeras 1, *
* Corresponding author
1 ROBOTVIS - Computer Vision and Robotics
CRISAM - Inria Sophia Antipolis - Méditerranée
Abstract : This paper deals with the problem of building three-dimen sional descriptions (we call them visual maps) of the environ ment of a mobile robot using passive vision. These maps are local (i.e., attached to specific frames of reference). Since noise is present, they incorporate information about the ge ometry of the environment and about the uncertainty of the parameters defining the geometry. This geometric uncertainty is directly related to its source (i.e., sensor uncertainty). We show how visual maps corresponding to different positions of the robot can be registered to compute a better estimate of its displacement between the various viewpoint positions, as suming an otherwise static environment. We use these esti mates to fuse the different visual maps and reduce locally the uncertainty of the geometric primitives which have found correspondents in other maps. We propose to perform these three tasks (building, registrating, and fusing visual maps) within the general framework of extended Kalman filtering, which allows efficient combination of measurements in the presence of noise.
Complete list of metadata
https://hal.inria.fr/inria-00615532
Contributor : Project-Team Asclepios Connect in order to contact the contributor
Submitted on : Friday, August 19, 2011 - 4:44:37 PM
Last modification on : Friday, February 4, 2022 - 3:19:39 AM
Long-term archiving on: : Friday, November 25, 2011 - 11:36:03 AM
File
AyacheIJRR1988.pdf
Identifiers
  • HAL Id : inria-00615532, version 1
Collections
Citation
Nicholas Ayache, Olivier Faugeras. Building, registrating and fusing noisy visual maps. The International Journal of Robotics Research, SAGE Publications, 1988, 7 (6), pp.45--65. ⟨inria-00615532⟩
Share
Metrics
Record views
280
Files downloads
225
