HYPER: a new approach for the recognition and positioning of 2D objects - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Pattern Analysis and Machine Intelligence Année : 1986
A new method has been designed to identify and locate objects lying on a flat surface. The merit of the approach is to provide strong robustness to partial occlusions (due for instance to uneven lighting conditions, shadows, highlights, touching and overlapping objects) thanks to a local and compact description of the objects boundaries and to a new fast recognition method involving generation and recursive evaluation of hypotheses named HYPER (HYpotheses Predicted and Evaluated Recursively). The method has been integrated within a vision system coupled to an indutrial robot arm, to provide automatk picking and repositioning of partially overlapping industrial parts.
Ayache-Faugeras-Pami86.pdf (7.89 Mo) Télécharger le fichier
inria-00615534 , version 1 (19-08-2011)
Nicholas Ayache, Olivier Faugeras. HYPER: a new approach for the recognition and positioning of 2D objects. IEEE Transactions on Pattern Analysis and Machine Intelligence, 1986, 8 (1), pp.44-54. ⟨10.1109/TPAMI.1986.4767751⟩. ⟨inria-00615534⟩
135 Consultations
571 Téléchargements
