Definition of a 4D continuous polar transformation for the tracking and the analysis of LV motion - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1997
A 4D polar transformation is defined to describe the left ventricle (LV) motion and a method is presented to estimate it from sequences of 3D images. The transformation is defined in 3D-planispheric coordinates by a small number of parameters involved in a set of simple linear equations. It is continuous and regular in time and space, periodicity in time can be imposed. The local motion can be easily decomposed into a few canonical motions (centripetal contraction, rotation around the long-axis, elevation). To recover the motion from original data, the 4D polar transformation is calculated using an adaptation of the Iterative Closest Point algorithm. We present the mathematical framework and a demonstration of its feasability on a gated SPECT sequence.
inria-00615691 , version 1 (19-08-2011)
Jérôme Declerck, Jacques Feldmar, Nicholas Ayache. Definition of a 4D continuous polar transformation for the tracking and the analysis of LV motion. First Joint Conference Computer Vision, Virtual Reality and Robotics in Medicine and Medical Robotics and Computer-Assisted Surgery - CVRMed-MRCAS' 97, Mar 1997, Grenoble, France. pp.33-42, ⟨10.1007/BFb0029222⟩. ⟨inria-00615691⟩
44 Consultations
0 Téléchargements
