Object Representation and Comparison Inferred from Its Medial Axis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2000
Eric Bardinet
  • Fonction : Auteur
S. Damas
  • Fonction : Auteur
N. Perez de La Blanca Capilla
  • Fonction : Auteur
The skeleton and its associated medial axis give a very compact representation of objects, even in the case of complex shapes and topologies. They are powerful shape descriptors, bridging the gap between low-level and highlevel object representations. Surprisingly, skeletons have been used in a relatively small number of applications. This work deals with the question of using the potential strength of the skeleton and the medial axis. From the medial axis, we build adequate attributed relational graphs to organize in a structured way informations about object shape and topology contained in the medial axis. This representation then permits to compare in a meaningful way various objects using a graph matching algorithm. Synthetic results are presented.
Fichier non déposé
inria-00615849 , version 1 (19-08-2011)
  • HAL Id : inria-00615849 , version 1
Eric Bardinet, Grégoire Malandain, S. Damas, N. Perez de La Blanca Capilla. Object Representation and Comparison Inferred from Its Medial Axis. International Conference on Pattern Recognition (ICPR 2000), 2000, Barcelone, Espagne, Spain. pp.1712--1715. ⟨inria-00615849⟩
91 Consultations
0 Téléchargements
