New interface
Journal articles
A three-dimensional, histological and deformable atlas of the human basal ganglia. I. Atlas construction based on immunohistochemical and MRI data
Abstract : This paper describes the construction of an atlas of the human basal ganglia. The successive steps of the construction were as follows. First a postmortem specimen was subjected to a MRI acquisition prior to extraction of the brain from the skull. The brain was then cryosectioned (70 mum thickness). One section out of ten (80 sections) was Nissl-stained with cresyl violet, another series of 80 sections was immunostained for the calcium binding protein calbindin. Contours of basal ganglia nuclei including their calbindin-stained functional subdivisions, fiber bundles and ventricles (n=80 structures) were traced from histological sections and digitized. A novelty of this atlas is the MRI acquisition, which represents the core data element of the study. MRI was used for the coregistration of the atlas data and permitted, through multimodal (Nissl, calbindin, images of cryosectioning, T1 and T2 MRI) and 3D optimization, the production of anatomically and geometrically consistent 3D surfaces, which can be sliced through any desired orientation. The atlas MRI is also used for its deformation to provide accurate conformation to the MRI of living patients, thus adding information at the histological level to the patient's MRI volume. This latter aspect will be presented in a forthcoming paper.
Complete list of metadata
https://hal.inria.fr/inria-00616029
Contributor : Project-Team Asclepios Connect in order to contact the contributor
Submitted on : Friday, August 19, 2011 - 6:40:22 PM
Last modification on : Friday, August 5, 2022 - 3:50:30 AM
Identifiers
  • HAL Id : inria-00616029, version 1
Citation
Jérôme Yelnik, Eric Bardinet, Didier Dormont, Grégoire Malandain, Sébastien Ourselin, et al.. A three-dimensional, histological and deformable atlas of the human basal ganglia. I. Atlas construction based on immunohistochemical and MRI data. NeuroImage, 2007, 34 (2), pp.618-38. ⟨inria-00616029⟩
Share
Metrics
Record views
154
