Effect of memantine on resting state default mode network activity in Alzheimer's disease - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Drugs and Aging Année : 2011
Background . Memantine is an approved symptomatic treatment for moderate to severe Alzheimer's Disease(AD) active on the excitotoxic effects of hyperactive glutamatergic transmission. The mechanism of the effect of memantine in AD patients is poorly known. The default mode network (DMN) is hypoactive in AD and is under glutamatergic control. Objective . To assess the effect of memantine on the activity of the DMN in moderate to severe AD. Methods. fMRI data of 15 moderate to severe AD patients, 7 (age 77±7, MMSE 16±4) treated with memantine and 8 with placebo (age 75±6, MMSE 13±4), were acquired at baseline (T0) and after 6 months of treatment (T6). Resting state components were extracted after spatial normalization on individual patients with independent component analysis. The consistency of the components was assessed using ICASSO and the DMN was recognized through spatial correlation with a pre- defined template. Voxel-based statistical analyses were performed to study the change of DMN activity from T0 to T6 in the two groups. Results . At T0, the two groups showed similar DMN activity except in the precuneus, where the treated showed slightly greater activity (p<0.05 corrected for family wise error). The prospective comparison between T0 and T6 in the treated showed increased DMN activation mapping to the precuneus (p<0.05 corrected), while the prospective comparison in the untreated did not show significant changes. The treatment x time interaction term was significant at p<0.05 corrected. Conclusions . The results suggest a positive effect of Memantine treatment in moderate to severe AD patients resulting in an increased resting activity in the precuneus region over 6 months. Future confirmatory analysis with adequately powered studies will be required to support the present findings.
Fichier non déposé
inria-00616182 , version 1 (19-08-2011)
  • HAL Id : inria-00616182 , version 1
Marco Lorenzi, Alberto Beltramello, Nicola Mercuri, Elisa Canu, Giada Zoccatelli, et al.. Effect of memantine on resting state default mode network activity in Alzheimer's disease. Drugs and Aging, 2011, 28 (3), pp.205-217. ⟨inria-00616182⟩
166 Consultations
0 Téléchargements
