Hysteresis thresholding for Wavelet denosing applied to P300 single-trial detection - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2011
Laurent Bougrain
Radu Ranta
Template-based analysis techniques are good candidates to robustly detect transient temporal graphic elements (e.g. event-related potential, k-complex, sleep spindles, vertex waves, spikes) in noisy and multi-sources electro-encephalographic signals. More specifically, we present the significant impact on a large dataset of wavelet denoisings to detect evoked potentials in a single-trial P300 speller. We apply the classical thresholds selection rules algorithms and compare them with the hysteresis algorithm presented in \cite{Ranta10hyst} which combine the classical thresholds to detect blocks of significant wavelets coefficients based on the graph structure of the wavelet decomposition.
Neurosciences
RR-7723.pdf (218.68 Ko) Télécharger le fichier
inria-00618694 , version 1 (02-09-2011)
inria-00618694 , version 2 (29-11-2011)
  • HAL Id : inria-00618694 , version 1
Carolina Saavedra, Laurent Bougrain, Radu Ranta. Hysteresis thresholding for Wavelet denosing applied to P300 single-trial detection. [Research Report] RR-7723, 2011, pp.5. ⟨inria-00618694v1⟩
155 Consultations
238 Téléchargements
