Location-aware service discovery on IPv6 GeoNetworking for VANET - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Service discovery is an essential component for applications in vehicular communication systems. While there have been numerous service discovery protocols dedicated to a local network, mobile ad-hoc networks and the Internet, in vehicular communication systems, applications pose additional requirements; They need to discover services according to geo- graphical position. In this paper, we propose a location-aware service discovery mechanism for Vehicular Ad-hoc NETwork (VANET). The proposed mechanism exploits IPv6 multicast on top of IPv6 GeoNetworking specified by the GeoNet project. Thanks to the GeoBroadcast mechanism, it efficiently propagates service discovery messages to a subset of nodes inside a relevant geographical area with encapsulating IPv6 multicast packets. We implemented the mechanism using CarGeo6, an open source implementation of IPv6 GeoNetworking. Our real field evaluation shows the system can discover services with low latency and low bandwidth usage in VANETs.
paper-satoru.pdf (235.25 Ko) Télécharger le fichier
ITST2011-slides-Satoru.pdf (1.95 Mo) Télécharger le fichier
Format : Autre
inria-00625796 , version 1 (22-09-2011)
  • HAL Id : inria-00625796 , version 1
Noguchi Satoru, Manabu Tsukada, Thierry Ernst, Atsuo Inomata, Kazutoshi Fujikawa. Location-aware service discovery on IPv6 GeoNetworking for VANET. ITST 2011 : 11th International Conference on Intelligent Transport System Telecommunications, Aug 2011, Saint-Petersburg, Russia. ⟨inria-00625796⟩
359 Consultations
439 Téléchargements
