Synthesis of Communicating Controllers for Distributed Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We consider the control of distributed systems composed of subsystems communicating asynchronously; the aim is to build local controllers that restrict the behavior of a distributed system in order to satisfy a global state avoidance property. We model our distributed systems as communicating finite state machines with reliable unbounded FIFO queues between subsystems. Local controllers can only observe their proper local subsystems and do not observe the queues. To refine their control policy, they can use the FIFO queues to communicate by piggybacking extra information to the messages sent by the subsystems. We define synthesis algorithms allowing to compute the local controllers. We explain how we can ensure the termination of this control algorithm by using abstract interpretation techniques, to overapproximate queue contents by regular languages. An implementation of our algorithms provides an empirical evaluation of our method.
cdc2011.pdf (507.05 Ko) Télécharger le fichier
inria-00627574 , version 1 (24-01-2012)
  • HAL Id : inria-00627574 , version 1
Gabriel Kalyon, Tristan Le Gall, Hervé Marchand, Thierry Massart. Synthesis of Communicating Controllers for Distributed Systems. IEEE Conference on Decision and Control and European Control Conference, Dec 2011, Orlando, United States. pp.1803-1810. ⟨inria-00627574⟩
147 Consultations
157 Téléchargements
