On the cactus rank of cubic forms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Symbolic Computation Année : 2013
Alessandra Bernardi
  • Fonction : Auteur
  • PersonId : 914887
Kristian Ranestad
  • Fonction : Auteur
  • PersonId : 911880
We prove that the smallest degree of an apolar $0$-dimensional scheme of a general cubic form in $n+1$ variables is at most $2n+2$, when $n\geq 8$, and therefore smaller than the rank of the form. For the general reducible cubic form the smallest degree of an apolar subscheme is $n+2$, while the rank is at least $2n$.
1110.2197.pdf (124.5 Ko) Télécharger le fichier
inria-00630456 , version 1 (10-10-2011)
inria-00630456 , version 2 (24-10-2011)
inria-00630456 , version 3 (28-11-2011)
Alessandra Bernardi, Kristian Ranestad. On the cactus rank of cubic forms. Journal of Symbolic Computation, 2013, 50, pp.291-297. ⟨10.1016/j.jsc.2012.08.001⟩. ⟨inria-00630456v3⟩
244 Consultations
223 Téléchargements
