New interface
Reports (Research report)
Anti-sparse coding for approximate nearest neighbor search
Hervé Jégou 1 Teddy Furon 1 Jean-Jacques Fuchs 2
1 TEXMEX - Multimedia content-based indexing
IRISA - Institut de Recherche en Informatique et Systèmes Aléatoires, Inria Rennes – Bretagne Atlantique
2 TEMICS - Digital image processing, modeling and communication
Abstract : This paper proposes a binarization scheme for vectors of high dimension based on the recent concept of anti-sparse coding, and shows its excellent performance for approximate nearest neighbor search. Unlike other binarization schemes, this framework allows, up to a scaling factor, the explicit reconstruction from the binary representation of the original vector. The paper also shows that random projections which are used in Locality Sensitive Hashing algorithms, are significantly outperformed by regular frames for both synthetic and real data if the number of bits exceeds the vector dimensionality, i.e., when high precision is required.
Complete list of metadata
Cited literature [12 references]  Display  Hide  Download
https://hal.inria.fr/inria-00633193
Contributor : Hervé Jégou Connect in order to contact the contributor
Submitted on : Monday, October 24, 2011 - 6:48:08 PM
Last modification on : Thursday, October 27, 2022 - 3:45:14 AM
Long-term archiving on: : Thursday, March 30, 2017 - 5:44:18 PM
RR-7771.pdf
Identifiers
  • HAL Id : inria-00633193, version 2
  • ARXIV : 1110.3767
Citation
Hervé Jégou, Teddy Furon, Jean-Jacques Fuchs. Anti-sparse coding for approximate nearest neighbor search. [Research Report] RR-7771, INRIA. 2011. ⟨inria-00633193v2⟩
Share
Metrics
Record views
638
Files downloads
553
