New interface
Journal articles
Use of proper orthogonal decomposition for the reduction of atmospheric chemical kinetics
Abstract : We investigate in this article a method based on proper orthogonal decompositions (POD) in order to reduce atmospheric chemical mechanisms. In a preliminary test, we apply this algorithm to the reduction of the CBM IV mechanism in a box model. The reduced basis computed with POD gives accurate results in its domain of validity while the CPU time needed for integration has been drastically lowered. The number of degrees of freedom of the local reduced model is 2 or 3. Moreover, we investigate some numerical strategies and a sensitivity analysis related to the choice of the reduced basis. This reducing technique is applied to three different scenarios for initial conditions: rural, urban, and polluted. Our tests indicate the deep relation with the slow-fast behavior of chemical kinetics.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/inria-00633799
Contributor : Nathalie Gaudechoux Connect in order to contact the contributor
Submitted on : Wednesday, October 19, 2011 - 2:23:23 PM
Last modification on : Wednesday, April 6, 2022 - 6:34:04 PM
Links full text
Identifiers
Collections
Citation
Bruno Sportisse, Rafik Djouad. Use of proper orthogonal decomposition for the reduction of atmospheric chemical kinetics. Journal of Geophysical Research, 2007, 112 (D06303), ⟨10.1029/2006JD007808⟩. ⟨inria-00633799⟩
Share
Metrics
Record views
69
