Two functions of analogical reasoning in design. A cognitive-psychology approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Design Studies Année : 1996
Willemien Visser
  • Fonction : Auteur
  • PersonId : 829708
On the basis of data collected in three empirical studies conducted on industrial designers, this paper identifies two different types of "spontaneous" use of analogy in design. Focus is on the first "stages" of analogical reasoning, i.e. construction of a target representation, and search and retrieval of a source. At the action-execution level, analogies are used in order to solve the current design problem; at the action-management level, in order to make the action-execution process cognitively more economical. Differences between the uses concern their dependence on the routine -character of the task, the distance between target and source, and their link with creativity and reuse (or case-based reasoning).
DesignStudies96_WVisser.pdf (274.08 Ko) Télécharger le fichier
inria-00633822 , version 1 (19-10-2011)
Willemien Visser. Two functions of analogical reasoning in design. A cognitive-psychology approach. Design Studies, 1996, Design Cognition and Computation, 17 (4), pp.417-434. ⟨10.1016/S0142-694X(96)00020-8⟩. ⟨inria-00633822⟩
Collections
INRIA INRIA2
123 Consultations
1260 Téléchargements
