Optimal and suboptimal protocols for a mathematical model for tumor anti-angiogenesis in combination with chemotherapy - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematical Biosciences and Engineering Année : 2011
We consider the problem of minimizing the tumor volume with a priori given amounts of anti-angiogenic and cytotoxic agents. For one underlying mathematical model, optimal and suboptimal solutions are given for four versions of this problem: the case when only anti-angiogenic agents are administered, combination treatment with a cytotoxic agent, and when a standard linear pharmacokinetic equation for the anti-angiogenic agent is added to each of these models. It is shown that the solutions to the more complex models naturally build upon the simplified versions. This gives credence to a modeling approach that starts with the analysis of simplified models and then adds increasingly more complex and medically relevant features. Furthermore, for each of the problem formulations considered here, there exist excellent simple piecewise constant controls with a small number of switchings that virtually replicate the optimal values for the objective.
LedzewiczMaurerSchaettler.pdf (1.94 Mo) Télécharger le fichier
inria-00636033 , version 1 (26-10-2011)
Urszula Ledzewicz, Helmut Maurer, Heinz Schaettler. Optimal and suboptimal protocols for a mathematical model for tumor anti-angiogenesis in combination with chemotherapy. Mathematical Biosciences and Engineering, 2011, 8 (2), pp.307-323. ⟨10.3934/mbe.2011.8.307⟩. ⟨inria-00636033⟩
301 Consultations
333 Téléchargements
