Reducing Equational Theories for the Decision of Static Equivalence - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Automated Reasoning Année : 2012
Static equivalence is a well established notion of indistinguishability of sequences of terms which is useful in the symbolic analysis of cryptographic protocols. Static equivalence modulo equational theories allows for a more accurate representation of cryptographic primitives by modelling properties of operators by equational axioms. We develop a method that allows us in some cases to simplify the task of deciding static equivalence in a multi-sorted setting, by removing a symbol from the term signature and reducing the problem to several simpler equational theories. We illustrate our technique at hand of bilinear pairings.
KMT-jar10.pdf (235.92 Ko) Télécharger le fichier
inria-00636797 , version 1 (07-10-2015)
Steve Kremer, Antoine Mercier, Ralf Treinen. Reducing Equational Theories for the Decision of Static Equivalence. Journal of Automated Reasoning, 2012, 48 (2), pp.197-217. ⟨10.1007/s10817-010-9203-0⟩. ⟨inria-00636797⟩
123 Consultations
94 Téléchargements
