Modes of ejecta emplacement at Martian craters from laboratory experiments of an expanding vortex ring interacting with a particle layer - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematical Research Letters Année : 2007
Y Nagata
  • Fonction : Auteur
K Kurita
  • Fonction : Auteur
Olivier S. Barnouin-Jha
  • Fonction : Auteur
[1] Ejecta morphologies of many Martian craters indicate fluidized emplacement which differs from ballistic emplacement in dry, airless environments. Double Layered Ejecta craters possess particularly interesting ejecta morphologies: two lobes and radial lineations on their surface, which probably result from gas-dominated radial flow during the emplacement. To examine how a radial flow interacts with surface particles to generate some of the observed morphologies on Mars, we have conducted water tank experiments in which a vortex ring encounters a particle layer. The threshold of particle motion and three interaction modes are described by two dimensionless numbers: particle Shields' parameter and particle Reynolds number. Our results show that gas-dominated flows are possible during cratering and could be used to constrain the ancient Martian environment from observations. Citation: Suzuki, A., I. Kumagai, Y. Nagata, K. Kurita, and O. S. Barnouin-Jha (2007), Modes of ejecta emplacement at Martian craters from laboratory experiments of an expanding vortex ring interacting with a particle layer, Geophys.
grlsuzuki-28372.pdf (155.46 Ko) Télécharger le fichier
insu-01270139 , version 1 (05-02-2016)
A Suzuki, I Kumagai, Y Nagata, K Kurita, Olivier S. Barnouin-Jha. Modes of ejecta emplacement at Martian craters from laboratory experiments of an expanding vortex ring interacting with a particle layer. Mathematical Research Letters, 2007, ⟨10.1029/2006GL028372⟩. ⟨insu-01270139⟩
81 Consultations
104 Téléchargements
