Mechanical origin of power law scaling in fault zone rock - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Geophysical Research Letters Année : 2007
Charles G. Sammis
  • Fonction : Auteur
Geoffrey C. P. King
  • Fonction : Auteur
  • PersonId : 841025
[1] A nearest neighbor fragmentation model, previously developed to explain observations of power law particle distributions in 3D with mass dimension D 3 % 2.6 (D 2 % 2.6 in 2D section) in low-strain fault gouge and breccia, is extended to the case of large strains to explain recent observations of D 3 % 3.0 (D 2 % 2.0 in 2D section) in the highly strained cores of many exhumed fault zones. At low strains, the elimination of same-sized nearest neighbors has been shown to produce a power law distribution which is characterized by a mass dimension near D 3 % 2.6. With increasing shear strain these isolated same-size neighbors can collide, in which case one of them fractures. The probability of two same size neighbors colliding and fragmenting in a simple shear flow is a function of the size and density of the two particles. Only for a power law distribution with D 3 = 3.0 is this collision probability independent of the size of the particles. Citation: Sammis,
grlsammis.pdf (172.32 Ko) Télécharger le fichier
insu-01270165 , version 1 (05-02-2016)
Charles G. Sammis, Geoffrey C. P. King. Mechanical origin of power law scaling in fault zone rock. Geophysical Research Letters, 2007, ⟨10.1029/2006GL028548⟩. ⟨insu-01270165⟩
111 Consultations
211 Téléchargements
