On the Backus Effect - II - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Geophysical Journal International Année : 1999
We again consider the problem of recovering the Earth's internal magnetic field B knowing its intensity IIBII at the Earth's surface and the location of the dip equator. In the present paper we focus on estimating the difference between two solutions B obtained from imperfect data. We explicitly estimate this difference and show that it converges to zero when the errors on IIBII and on the location of the dip equator E both tend to zero.
Geophys. J. Int.-1999-Khokhlov-816-20.pdf (290.38 Ko) Télécharger le fichier
insu-01409673 , version 1 (06-12-2016)
G Khokhlov, G Hulot, J.-L Le Mouël. On the Backus Effect - II. Geophysical Journal International, 1999, 137 (3), pp.816-820. ⟨10.1046/j.1365-246x.1999.00843.x⟩. ⟨insu-01409673⟩
31 Consultations
72 Téléchargements
