Two hundred thirty years of relative sea level changes due to climate and megathrust tectonics recorded in coral microatolls of Martinique (French West Indies) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Geophysical Research : Solid Earth Année : 2016
We sampled six coral microatolls that recorded the relative sea level changes over the last 230 years east of Martinique, on fringing reefs in protected bays. The microatolls are cup-shaped, which is characteristic of corals that have been experiencing submergence. X-ray analysis of coral slices and reconstructions of the highest level of survival (HLS) curves show that they have submerged at rates of a few millimeters per year. Their morphology reveals changes in submergence rate around 1829 ± 11, 1895, and 1950. Tide gauges available in the region indicate a regional sea level rise at a constant mean rate of 1.1 ± 0.8 mm/yr, which contrasts with our coral record, implying additional tectonic subsidence. Comparing our coral morphology with that of synthetic corals generated with Matlab by using the Key West tide gauge record (Florida), we show that their growth was controlled by tectonics and that a sudden relative sea level increase drowned them around 1950. Simple elastic models show that this sudden submergence probably occurred during the 21 May 1946 earthquake, which ruptured the plate interface in front of Martinique, in the mantle wedge, in an area of sustained seismic activity. The 1839 M8+ earthquake probably occurred in the same area. Long-term subsidence of microatolls indicates that this deep portion of the megathrust is probably locked down to 60 km depth during the interseismic period. Our oldest coral recorded a long-lasting period (50 years) of stable relative sea level after the 1839 earthquake, indicating that transient interseismic strain rate variations may occur in the Lesser Antilles.
Weil-Accardo_et_al-2016-Journal_of_Geophysical_Research__Solid_Earth.pdf (8.18 Mo) Télécharger le fichier
insu-01470290 , version 1 (17-02-2017)
Jennifer Weil-Accardo, Nathalie Feuillet, Eric Jacques, Pierre Deschamps, François Beauducel, et al.. Two hundred thirty years of relative sea level changes due to climate and megathrust tectonics recorded in coral microatolls of Martinique (French West Indies). Journal of Geophysical Research : Solid Earth, 2016, 121 (4), pp.2873-2903. ⟨10.1002/2015JB012406⟩. ⟨insu-01470290⟩
428 Consultations
207 Téléchargements
