Understanding Himalayan erosion and the significance of the Nicobar Fan - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Earth and Planetary Science Letters Année : 2017
Jan Backman
  • Fonction : Auteur
Hideki Mukoyoshi
  • Fonction : Auteur
Wenhuang Chen
  • Fonction : Auteur
Sarah Kachovich
  • Fonction : Auteur
Freya L. Mitchison
  • Fonction : Auteur
Tobias A. Colson
  • Fonction : Auteur
Mari Frederik
  • Fonction : Auteur
Brian M. House
  • Fonction : Auteur
Andre Hüpers
  • Fonction : Auteur
Tamara N. Jeppson
  • Fonction : Auteur
Abby R. Kenigsberg
  • Fonction : Auteur
Mebae Kuranaga
  • Fonction : Auteur
Nisha Nair
  • Fonction : Auteur
Satoko Owari
  • Fonction : Auteur
Yehua Shan
  • Fonction : Auteur
Insun Song
  • Fonction : Auteur
Marta E. Torres
  • Fonction : Auteur
Paola Vannucchi
  • Fonction : Auteur
Peter J. Vrolijk
  • Fonction : Auteur
Xixi Zhao
  • Fonction : Auteur
Ellen Thomas
  • Fonction : Auteur
A holistic view of the Bengal–Nicobar Fan system requires sampling the full sedimentary section of the Nicobar Fan, which was achieved for the first time by International Ocean Discovery Program (IODP) Expedition 362 west of North Sumatra. We identified a distinct rise in sediment accumulation rate (SAR) beginning ∼9.5 Ma and reaching 250–350 m/Myr in the 9.5–2 Ma interval, which equal or far exceed rates on the Bengal Fan at similar latitudes. This marked rise in SAR and a constant Himalayan-derived provenance necessitates a major restructuring of sediment routing in the Bengal–Nicobar submarine fan. This coincides with the inversion of the Eastern Himalayan Shillong Plateau and encroachment of the west-propagating Indo–Burmese wedge, which reduced continental accommodation space and increased sediment supply directly to the fan. Our results challenge a commonly held view that changes in sediment flux seen in the Bengal–Nicobar submarine fan were caused by discrete tectonic or climatic events acting on the Himalayan–Tibetan Plateau. Instead, an interplay of tectonic and climatic processes caused the fan system to develop by punctuated changes rather than gradual progradation.
Tectonique
McNeill-2017.pdf (2.3 Mo) Télécharger le fichier
insu-01579460 , version 1 (22-11-2017)
Paternité
Lisa C. Mcneill, Brandon Dugan, Jan Backman, Kevin T. Pickering, Hugo Pouderoux, et al.. Understanding Himalayan erosion and the significance of the Nicobar Fan. Earth and Planetary Science Letters, 2017, 475, pp.134-142. ⟨10.1016/j.epsl.2017.07.019⟩. ⟨insu-01579460⟩
1310 Consultations
196 Téléchargements
