Ozone Profile Retrieval from nadir TROPOMI measurements in the UV range - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Atmospheric Measurement Techniques Année : 2021
The TOPAS algorithm to retrieve vertical profiles of ozone from space-borne observations in nadir viewing geometry has been developed at the Institute of Environmental Physics (IUP) of the University of Bremen and applied to TROPOMI L1B spectral data version 2. The spectral data between 270 and 329 nm are used for the retrieval. A re-calibration of the measured radiances is done using ozone profiles from MLS/Aura. Studies with synthetic spectra show that individual profiles in the stratosphere can be retrieved with the accuracy of about 10%. In the troposphere, the retrieval errors are larger depending on the a-priori profile used. The vertical resolution above 18 km is about 6-10 km and it degrades to 15-25 km below. The vertical resolution in the troposphere is strongly dependent on the solar zenith angle (SZA). The ozone profiles retrieved from TROPOMI with the TOPAS algorithm were validated using data from ozone sondes and stratospheric ozone lidars. Above 18 km, the comparison with sondes shows excellent agreement within less than ± 5% for all latitudes. The standard deviation of mean differences is about 10%. Below 18 km, the relative mean deviation in the tropics and northern latitudes is still quite good remaining within ± 20%. At southern latitudes larger differences of up to +40% occur between 10 and 15 km. The standard deviation is about 50% between 7-18 km and about 25% below 7 km. The validation of stratospheric ozone profiles with ground-based lidar measurements also shows very good agreement. The relative mean deviation is below ± 5% between 18-45 km with a standard deviation of 10%. TOPAS retrieval results for one day of TROPOMI observations were compared to MLS and OMPS-LP data. The relative mean difference was found to be largely below ±5% between 20-50 km with exception of very high latitudes.
amt-14-6057-2021.pdf (8.38 Mo) Télécharger le fichier
insu-03173556 , version 1 (18-03-2021)
insu-03173556 , version 2 (17-09-2021)
Paternité
Nora Mettig, Mark Weber, Alexei Rozanov, Carlo Arosio, John P. Burrows, et al.. Ozone Profile Retrieval from nadir TROPOMI measurements in the UV range. Atmospheric Measurement Techniques, 2021, 14 (9), pp.6057-6082. ⟨10.5194/amt-14-6057-2021⟩. ⟨insu-03173556v2⟩
79 Consultations
36 Téléchargements
