Variability of Sea-Surface Magnetic Anomalies at Ultraslow Spreading Centers: Consequence of Detachment Faulting and Contrasted Magmatism? - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Geophysical Research Letters Année : 2022
The capacity of oceanic crust to record geomagnetic polarity reversals makes sea-surface magnetic anomalies an essential tool to study plate tectonics. The anomalies are usually well-defined at magmatic spreading centers, but are distorted and eventually disappear on magma-poor mid-ocean ridges such as the ultraslow Southwest Indian Ridge (SWIR), making their interpretation difficult. We attribute the variability of the SWIR sea-surface magnetic anomalies to the alternance of magmatic spreading and detachment faulting. A three-layer magnetic model is used to simulate the influence of such an alternance on the sea-surface magnetic anomalies. Conversely, observed magnetic profiles at the SWIR are modeled to unravel their off-axis crustal structure and past mode of spreading. The intruding gabbro bodies on the footwall of detachment faults play a major role in explaining the variability of sea-surface magnetic anomalies at slow and ultraslow spreading ridges.
Geophysical Research Letters - 2022 - Zhou - Variability of Sea%E2%80%90Surface Magnetic Anomalies at Ultraslow Spreading Centers .pdf (577.89 Ko) Télécharger le fichier
insu-03643048 , version 1 (18-08-2022)
Copyright (Tous droits réservés)
F. Zhou, J. Dyment. Variability of Sea-Surface Magnetic Anomalies at Ultraslow Spreading Centers: Consequence of Detachment Faulting and Contrasted Magmatism?. Geophysical Research Letters, 2022, 49, ⟨10.1029/2021GL097276⟩. ⟨insu-03643048⟩
46 Consultations
27 Téléchargements
