Surface-to-space atmospheric waves from Hunga Tonga-Hunga Ha’apai eruption - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Nature Année : 2022
Lars Hoffmann
Marie Bouillon
Cathy Clerbaux
The January 2022 Hunga Tonga–Hunga Haʻapai eruption was one of the most explosive volcanic events of the modern era1,2, producing a vertical plume which peaked > 50km above the Earth3. The initial explosion and subsequent plume triggered atmospheric waves which propagated around the world multiple times4. A global-scale wave response of this magnitude from a single source has not previously been observed. Here we show the details of this response, using a comprehensive set of satellite and ground-based observations to quantify it from surface to ionosphere. A broad spectrum of waves was triggered by the initial explosion, including Lamb waves5,6 propagating at phase speeds of 318.2±6 ms-1 at surface level and between 308±5 to 319±4 ms-1 in the stratosphere, and gravity waves7 propagating at 238±3 to 269±3 ms-1 in the stratosphere. Gravity waves at sub-ionospheric heights have not previously been observed propagating at this speed or over the whole Earth from a single source8,9. Latent heat release from the plume remained the most significant individual gravity wave source worldwide for >12 hours, producing circular wavefronts visible across the Pacific basin in satellite observations. A single source dominating such a large region is also unique in the observational record. The Hunga Tonga eruption represents a key natural experiment in how the atmosphere responds to a sudden point-source-driven state change, which will be of use for improving weather and climate models.
s41586-022-05012-5-1.pdf (12.46 Mo) Télécharger le fichier
insu-03741099 , version 1 (27-11-2022)
Paternité - Pas d'utilisation commerciale
Corwin J. Wright, Neil P. Hindley, M. Joan Alexander, Mathew Barlow, Lars Hoffmann, et al.. Surface-to-space atmospheric waves from Hunga Tonga-Hunga Ha’apai eruption. Nature, 2022, 609, pp.741-746. ⟨10.1038/s41586-022-05012-5⟩. ⟨insu-03741099⟩
119 Consultations
16 Téléchargements
