What can Hurricane SAM (2021) tell us about ocean waves under tropical cyclones? - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2024
Xiaolu Zhao
  • Fonction : Auteur
  • PersonId : 1380489
Ludivine Oruba
  • Fonction : Auteur
  • PersonId : 1029193
Danièle Hauser
We investigate the ocean wave eld under Hurricane SAM (2021). Whilst measurements of waves under Tropical Cyclones (TCs) are rare, an unusually large number of quality in situ and remote mea- surements are available in that case. First, we highlight the good consistency between the wave spectra provided by the Surface Waves Investigation and Monitoring (SWIM) instrument onboard the China- France Oceanography Satellite (CFOSAT), the in situ spectra mea- sured by National Data Buoy Center (NDBC) buoys, and a saildrone. The impact of strong rains on SWIM spectra is then further investi- gated. We show that whereas the rain de nitely a ects the normalized radar cross section, both the innovative technology (beam rotating scanning geometry) and the post-processing processes applied to re- trieve the 2D wave spectra ensure a good quality of the resulting wave spectra, even in heavy rain conditions. On this basis, the satellite, air- borne and in situ observations are confronted to the analytical model proposed by Kudryavtsev et al (2015). We show that a trapped wave mechanism may be invoked to explain the large signi cant wave height observed in the right front quadrant of Hurricane SAM.
Océanographie
2404.13457v1.pdf (23.67 Mo) Télécharger le fichier
insu-04568091 , version 1 (03-05-2024)
Xiaolu Zhao, Ludivine Oruba, Danièle Hauser, B Zhang, E Dormy. What can Hurricane SAM (2021) tell us about ocean waves under tropical cyclones?. 2024. ⟨insu-04568091⟩
0 Consultations
0 Téléchargements
