Analyzing the Logic Behavior of Digital CMOS Circuits in Presence of Simultaneous Switching Noise - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
This paper analyzes the logic errors in digital circuits due to the presence of Simultaneous Switching Noise (SSN). It is demonstrated that 2 conditions must be fulfilled in order to guarantee the correct logic behaviour of a digital circuits. The first condition called ‘Minimum Switch Condition' is proved to be fulfilled whatever the amount of SSN in the power and ground lines. The second condition called ‘Signal Coherence Condition' is proved to be fulfilled within power coherent logic blocks. However the interface between non-coherent logic blocks may originate logic dysfunction
3analysing.pdf (414.64 Ko) Télécharger le fichier
lirmm-00199261 , version 1 (21-01-2017)
  • HAL Id : lirmm-00199261 , version 1
Florence Azaïs, Laurent Larguier, Michel Renovell. Analyzing the Logic Behavior of Digital CMOS Circuits in Presence of Simultaneous Switching Noise. LATW: Latin American Test Workshop, Mar 2007, Cuzco, Peru. ⟨lirmm-00199261⟩
100 Consultations
150 Téléchargements
