Design-for-manufacturability of MEMS convective accelerometers through adaptive electrical calibration strategy - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we explore the use of an adaptive electrical calibration strategy in the context of design-for-manufacturing for MEMS convective accelerometers. The calibration principle relies on the adjustment of the heater power level such that sensitivity is set to a given target value. The idea is to define multiple sensitivity targets in order to improve production yield and to insert a criterion on power consumption. Different device binning can then be achieved depending on test limit settings. Results obtained from Monte-Carlo simulation are presented to demonstrate potentialities of the technique.
S03-2-LATW2012.pdf (969.43 Ko) Télécharger le fichier
lirmm-00803451 , version 1 (21-01-2017)
Ahmed Rekik, Florence Azaïs, Frédérick Mailly, Pascal Nouet. Design-for-manufacturability of MEMS convective accelerometers through adaptive electrical calibration strategy. LATW: Latin American Test Workshop, Apr 2012, Quito, Ecuador. ⟨10.1109/LATW.2012.6261237⟩. ⟨lirmm-00803451⟩
165 Consultations
245 Téléchargements
