CloudMdsQL: Querying Heterogeneous Cloud Data Stores with a Common Language - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Distributed and Parallel Databases Année : 2016
Boyan Kolev
Patrick Valduriez
Carlyna Bondiombouy
Raquel Pau
  • Fonction : Auteur
  • PersonId : 968821
The blooming of different cloud data management infrastructures, special-ized for different kinds of data and tasks, has led to a wide diversification of DBMS interfaces and the loss of a common programming paradigm. In this paper, we present the design of a Cloud Multidatastore Query Language (CloudMdsQL), and its query engine. CloudMdsQL is a functional SQL-like language, capable of querying multiple heterogeneous data stores (relational and NoSQL) within a single query that may contain embedded invocations to each data store’s native query interface. The query engine has a fully distributed architecture, which provides important opportunities for optimization. The major innovation is that a CloudMdsQL query can exploit the full power of local data stores, by simply allowing some local data store native queries (e.g. a breadth-first search query against a graph database) to be called as functions, and at the same time be optimized, e.g. by pushing down select predicates, using bind join, performing join ordering, or planning intermediate data shipping. Our experi-mental validation, with three data stores (graph, document and relational) and repre-sentative queries, shows that CloudMdsQL satisfies the five important requirements for a cloud multidatastore query language.
CloudMdsQL-DAPD-final.pdf (914.65 Ko) Télécharger le fichier
lirmm-01184016 , version 1 (09-12-2015)
Boyan Kolev, Patrick Valduriez, Carlyna Bondiombouy, Ricardo Jiménez-Peris, Raquel Pau, et al.. CloudMdsQL: Querying Heterogeneous Cloud Data Stores with a Common Language. Distributed and Parallel Databases, 2016, 34 (4), pp.463-503. ⟨10.1007/s10619-015-7185-y⟩. ⟨lirmm-01184016⟩
744 Consultations
759 Téléchargements
