Experimental Heavy-Ion SEU Cross-Sections Of Sram Memory Components - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Alexandre Louis Bosser
Viyas Gupta
  • Fonction : Auteur
  • PersonId : 1231992
Mario Rossi
  • Fonction : Auteur
Ari Virtanen
  • Fonction : Auteur
In this work the heavy ion induced Single Event Upset (SEU) cross-sections and resulting failure rates of SRAM memory components were studied.
Physics Days_2014.pdf (67.5 Ko) Télécharger le fichier
lirmm-01238439 , version 1 (22-07-2019)
  • HAL Id : lirmm-01238439 , version 1
Alexandre Louis Bosser, Luigi Dilillo, Viyas Gupta, Arto Javanainen, Heikki Kettunen, et al.. Experimental Heavy-Ion SEU Cross-Sections Of Sram Memory Components. Physics Days, Finnish Physical Society, Tampere University of Technology (TUT), and Tavicon Ltd., Mar 2014, Tampere, Finland. ⟨lirmm-01238439⟩
161 Consultations
44 Téléchargements
