Materializing Knowledge Bases via Trigger Graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Proceedings of the VLDB Endowment (PVLDB) Année : 2021
The chase is a well-established family of algorithms used to materialize Knowledge Bases (KBs) for tasks like query answering under dependencies or data cleaning. A general problem of chase algorithms is that they might perform redundant computations. To counter this problem, we introduce the notion of Trigger Graphs (TGs), which guide the execution of the rules avoiding redundant computations. We present the results of an extensive theoretical and empirical study that seeks to answer when and how TGs can be computed and what are the benefits of TGs when applied over real-world KBs. Our results include introducing algorithms that compute (minimal) TGs. We implemented our approach in a new engine, called GLog, and our experiments show that it can be significantly more efficient than the chase enabling us to materialize Knowledge Graphs with 17B facts in less than 40 min using a single machine with commodity hardware.
trigger-graphs-tr.pdf (974.17 Ko) Télécharger le fichier
lirmm-03344217 , version 1 (14-09-2021)
Efthymia Tsamoura, David Carral, Enrico Malizia, Jacopo Urbani. Materializing Knowledge Bases via Trigger Graphs. Proceedings of the VLDB Endowment (PVLDB), 2021, 14 (6), pp.943-956. ⟨10.14778/3447689.3447699⟩. ⟨lirmm-03344217⟩
88 Consultations
9057 Téléchargements
