Effect of nuclear architecture on the efficiency of double-strand break repair - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Nature Cell Biology Année : 2013
The most dangerous insults to the genome's integrity are those that break both strands of the DNA. Double-strand breaks can be repaired by homologous recombination; in this conserved mechanism, a global genomic homology search finds sequences similar to those near the break, and uses them as a template for DNA synthesis and ligation. Chromosomes occupy restricted territories within the nucleus. We show that yeast genomic regions whose nuclear territories overlap recombine more efficiently than sequences located in spatially distant territories. Tethering of telomeres and centromeres reduces the efficiency of recombination between distant genomic loci, lowering the chances of non-allelic recombination. Our results challenge present models that posit an active scanning of the whole nuclear volume by the broken chromosomal end; they demonstrate that the search for homology is a limiting step in homologous recombination, and emphasize the importance of nuclear organization in genome maintenance.
Fichier non déposé
pasteur-02446715 , version 1 (21-01-2020)
Neta Agmon, Batia Liefshitz, Christophe Zimmer, Emmanuelle Fabre, Martin Kupiec. Effect of nuclear architecture on the efficiency of double-strand break repair. Nature Cell Biology, 2013, 15 (6), pp.694-699. ⟨10.1038/ncb2745⟩. ⟨pasteur-02446715⟩
16 Consultations
1 Téléchargements
