Generation of gene-level resolution chromosome contact maps in bacteria and archaea - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue STAR Protocols Année : 2021
Chromosome conformation capture (Hi-C) has become a routine method for probing the 3D organization of genomes. However, when applied to bacteria and archaea, current protocols are expensive and limited in their resolution. By dissecting the different steps of published eukaryotic and prokaryotic Hi-C protocols, we have developed a cost- and time-effective approach to generate high-resolution (down to 500 bp - 1 kb) contact matrices of both bacteria and archaea genomes.
1-s2.0-S2666166721002197-main.pdf (2.84 Mo) Télécharger le fichier
Origine : Publication financée par une institution
pasteur-03376845 , version 1 (13-10-2021)
Paternité - Pas d'utilisation commerciale - Pas de modification
Charlotte Cockram, Agnès Thierry, Romain Koszul. Generation of gene-level resolution chromosome contact maps in bacteria and archaea. STAR Protocols, 2021, 2 (2), pp.100512. ⟨10.1016/j.xpro.2021.100512⟩. ⟨pasteur-03376845⟩
14 Consultations
98 Téléchargements
