Generating High-Resolution Hi-C Contact Maps of Bacteria - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2021
During the past decade, Chromosome Conformation Capture (3C/Hi-C)-based methods have been used to probe the 3D structure and organization of bacterial genomes, revealing fundamental aspects of chromosome dynamics. However, the current protocols are expensive, inefficient, and limited in their resolution. Here we present a simple, cost-effective Hi-C approach that is readily applicable to a range of Gram-positive and Gram-negative bacteria.
2020-Thierry_and_Cockram_chapter_2020-06.pdf (229.79 Ko) Télécharger le fichier
pasteur-03686079 , version 1 (07-06-2022)
Paternité - Pas d'utilisation commerciale
Agnès Thierry, Charlotte Cockram. Generating High-Resolution Hi-C Contact Maps of Bacteria. Hi-C Data Analysis, 2301, Springer US, pp.183-195, 2021, Methods in Molecular Biology, 978-1-0716-1390-0. ⟨10.1007/978-1-0716-1390-0_9⟩. ⟨pasteur-03686079⟩
98 Consultations
208 Téléchargements
