ON REGULAR AND SINGULAR POINTS OF THE MINIMUM TIME FUNCTION - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2014
Sur les points réguliers et singuliers de la fonction du temps minimal
In this thesis, we study the regularity of the minimum time function $T$ for both linear and nonlinear control systems in Euclidean space. We first consider nonlinear problems satisfying Petrov condition. In this case, $T$ is locally Lipschitz and then is differentiable almost everywhere. In general, T fails to be differentiable at points where there are multiple time optimal trajectories and its differentiability at a point does not guarantee continuous differentiability around this point. We show that, under some regularity assumptions, the non-emptiness of proximal subdifferential of the minimum time function at a point $x$ implies its continuous differentiability on a neighborhood of $x$. The technique consists of deriving sensitivity relations for the proximal subdifferential of the minimum time function and excluding the presence of conjugate points when the proximal subdifferential is nonempty. We then study the regularity the minimum time function $T$ to reach the origin under controllability conditions which do not imply the Lipschitz continuity of $T$. Basing on the analysis of zeros of the switching function, we find out singular sets (e.g., non - Lipschitz set, non - differentiable set) and establish rectifiability properties for them. The results imply further regularity properties of $T$ such as the SBV regularity, the differentiability and the analyticity. The results are mainly for linear control problems.
Dans cette thèse, nous étudions la régularité de la fonction temps minimal à la fois pour les systèmes contrôllés linéaire et non linéaires, dans un espace euclidien. Nous considérons d'abord des problèmes non linéaires satisfaisant la condition de Petrov. Dans ce cas, la fonction du temps minimal est localement Lipschitz et donc dérivable presque partout. En général, la fonction temps minimal n’est pas dérivable aux points où il y a plusieurs trajectoires optimales. De plus, la différentiabilité de la fonction temps minimal en un point ne garantit pas différentiabilité continue autour de ce point. Nous montrons que, sous certaines hypothèses de régularité, le fait que sous-différentiel proximale de la fonction d'un minimum de temps à un point $x$ soit non-vide implique la différentiabilité continue de la fonction sur un voisinage de $x$. La technique de preuve consiste à dériver les relations de sensibilité pour le sous-différentiel proximal de la fonction de temps minimum et à montrer l’absence de points conjugué lorsque le sous-différentiel proximal n’est pas vide. Nous étudions ensuite la régularité de la fonction minimum de temps pour atteindre l'origine sous des conditions de contrôlabilité qui n’impliquent pas la continuité de Lipschitz de la fonction. En analysant l’ensemble des zéros de la fonction de commutation, nous décrivons les ensembles singuliers (par exemple, ensemble non-Lipschitz ou non-différentiable) et établissons des propriétés de rectifiabilité pour ces ensembles.
Luong-Thesis-Finalversion.pdf (3.73 Mo) Télécharger le fichier
tel-01127728 , version 1 (07-03-2015)
  • HAL Id : tel-01127728 , version 1
Nguyen van Luong. ON REGULAR AND SINGULAR POINTS OF THE MINIMUM TIME FUNCTION . Optimization and Control [math.OC]. University of Padova, 2014. English. ⟨NNT : ⟩. ⟨tel-01127728⟩
87 Consultations
118 Téléchargements
