Etude des effets de la motivation scolaire, de l'estime de soi et du rôle médiateur de la dépression dans le risque de décrochage scolaire au collège et au lycée - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2014
A study of the effects of academic motivation, self-esteem and the mediating role of depression in dropout risk in midlle and high school
Research on school drop-out has led to consider early school leaving as a medium- or long-term process down a path marked with numerous difficulties, as much on a personal and family level as educational (French Ministry of Education, 2012). These factors make a student's school éducation vulnerable, particularly for boys who generally experience more difficulty adapting to school than girls do (Royer, 2010). More recently, studies including psychological factors have pointed out the relevance of a more personalised préventive approach, based on the student's own educational experience. The goal of this thesis was to analyse the influence of self-esteem, academic motivation and dépression on the risk of dropping out, using quantitative methods on a sample of 265 middle- and high-school students in the general sector. First of all, we studied the above factors of self-esteem, academic motivation and dépression in relation to the sex and age of the students, taking into account the complexity of these three dimensions (Gurtner, Gorga, Monnard et Ntamakiliro, 2001 ; Harter, 1988 ). The results obtained correspond to the commonly held viewpoint that girls are more motivated and committed to their education and manifest more dépressive states than boys, while boys have a higher self-esteem. The results also show that the older students are, the less they are motivated and therefore more likely to drop out. Secondly, we studied the influence of these factors on the risk of drop-out. In particular, we pointed out the mediating role of depression in the established link between self-esteem in the area of morality and behavior and that of a state of anxiety towards maths and French with a risk of dropping out. More specifically, the study revealed that this same role played by depression is even more determinant for boys, making psychological distress an essential risk factor in the process of teenage dropout (Quiroga, Janosz et Marcotte, 2006). The research and analysis carried out for this thesis confirm the importance of focusing on the personal risk factors in order to understand the process that could lead a student to disconnect from school. It also shows that these personal factors become the central question for boys, since unlike girls, they seem to demonstrate more difficulties of a psychological order, creating a higher risk of dropout.
Les recherches qui se sont intéressées à l'étude du décrochage scolaire ont conduit à considérer l'abandon des études comme un processus qui s'inscrit à moyen ou long terme dans un parcours jalonné de nombreuses difficultés tant sur le plan personnel, que familial et scolaire (Ministère de l'Éducation nationale, 2012). Ces facteurs fragilisent la scolarité des élèves, en particulier celle des garçons qui montrent en général plus de problèmes d'adaptation à l'école que les filles (Royer, 2010). Plus récemment, les études prenant en considération les facteurs psychologiques ont mis en évidence la pertinence d'une approche préventive plus individualisée, ciblée sur l'expérience scolaire des élèves. L'objectif de cette thèse était d'analyser à partir d'une méthodologie quantitative l'influence de l'estime de soi, de la motivation scolaire et de la dépression sur le risque de décrochage scolaire auprès d'un échantillon de 265 élèves scolarisés au collège et au lycée dans des filières générales. Dans un premier temps, nous avons étudié ces facteurs en fonction du sexe et de l'âge des élèves en prenant en compte la complexité des dimensions étudiées (Gurtner, Gorga, Monnard et Ntamakiliro, 2001 ; Harter, 1988 ). Les résultats que nous avons obtenus vont dans le sens du regard généralement porté sur ces dimensions, à savoir que les filles sont plus motivées et plus engagées dans leur scolarité, qu'elles présentent plus d'états dépressifs, alors que les garçons ont une meilleure estime d'eux-mêmes. Ils montrent également que plus les élèves sont âgés, moins ils sont motivés et plus ils présentent de risque de décrochage scolaire. Dans un second temps, nous nous sommes intéressés à l'influence des ces facteurs sur le risque de décrochage scolaire. Nous avons notamment montré le rôle médiateur de la dépression dans le lien entretenu entre l'estime de soi dans le domaine de la moralité et des conduites et l'état d'anxiété envers les mathématiques et le français avec le risque de décrochage scolaire. Plus spécifiquement, nous avons pu mettre en évidence que ce rôle joué par la dépression était d'autant plus important concernant les garçons, faisant de la détresse psychologique un facteur de risque incontournable dans le processus d'abandon scolaire des adolescents (Quiroga, Janosz et Marcotte, 2006). Ce travail de thèse confirme l'importance de s'attacher aux facteurs de risque personnels dans la compréhension des processus pouvant conduire un élève à rompre le lien avec l'école. Il montre également que cette question est centrale pour les garçons puisque ces derniers montreraient plus de difficultés d'ordre psychologique les conduisant à présenter plus de risque de décrochage scolaire que les filles.
30917_SCELLOS_2014_diffusion.pdf (3.9 Mo) Télécharger le fichier
tel-01144478 , version 1 (21-04-2015)
  • HAL Id : tel-01144478 , version 1
Jérémie Scellos. Etude des effets de la motivation scolaire, de l'estime de soi et du rôle médiateur de la dépression dans le risque de décrochage scolaire au collège et au lycée. Psychologie. Université de Grenoble, 2014. Français. ⟨NNT : 2014GRENH009⟩. ⟨tel-01144478⟩
2826 Consultations
26744 Téléchargements
