Contribution à la spécification et à la vérification des logiciels à base de composants : enrichissement du langage de données de Kmelia et vérication de contrats - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2011
Contribution to Specifying and Verifying Component-based Software: enrichment of the Kmelia data language and contract verification
With Model Driven Engineering models are the heart of software development. These models evolve through transformations. In this thesis our interest was the validation for these model transformations by testing, and more precisely the test oracles. We propose two approaches to assist the tester to create these oracles. With the first ap- proach this assistance is passive; we provide the tester with a new oracle function. The test oracles created with this new oracle function control only part of the model produced by the transformation under test. We defined the notion of partial verdict, described the situations where having a partial verdict is beneficial for the tester and how to test a transformation in this context. We developed a tool implementing this proposal, and ran experiments with it. With the second approach, we provide a more active assistance about test oracles’ quality. We study the quality of a set of model transformation test oracles. We consider that the quality of a set of oracles is linked to its ability to detect faults in the transformation under test. We show the limits of mutation analysis which is used for this purpose, then we propose a new approach that corrects part of these drawbacks. We measure the coverage of the output meta-model by the set of oracles we consider. Our approach does not depend on the language used for the transformation under test’s implementation. It also provides the tester with hints on how to improve her oracles. We defined a process to evaluate meta-model coverage and qualify test oracles. We developed a tool implementing our approach to validate it through experimentations.
L'utilisation croissante des composants et des services logiciels dans les différents secteurs d'activité (télécommunications, transports, énergie, finance, santé, etc.) exige des moyens (modèles, méthodes, outils, etc.) rigoureux afin de maîtriser leur production et d'évaluer leur qualité. En particulier, il est crucial de pouvoir garantir leur bon fonctionnement en amont de leur déploiement lors du développement modulaire de systèmes logiciels. Kmelia est un modèle à composants multi-services développé dans le but de construire des composants logiciels et des assemblages prouvés corrects. Trois objectifs principaux sont visés dans cette thèse. Le premier consiste à enrichir le pouvoir d'expression du mod èle Kmelia avec un langage de données afin de satisfaire le double besoin de spécification et de vérification. Le deuxième vise l'élaboration d'un cadre de développement fondé sur la notion de contrats multi-niveaux. L'intérêt de tels contrats est de maîtriser la construction progressive des systèmes à base de composants et d'automatiser le processus de leur véri- fication. Nous nous focalisons dans cette thèse sur la vérification des contrats fonctionnels en utilisant la méthode B. Le troisième objectif est l'instrumentation de notre approche dans la plate-forme COSTO/Kmelia. Nous avons implanté un prototype permettant de connecter COSTO aux différents outils associés à la méthode B. Ce prototype permet de construire les machines B à partir des spécifications Kmelia en fonction des propriétés à vé- rifier. Nous montrons que la preuve des spécifications B générées garantit la cohérence des spécifications Kmelia de départ. Les illustrations basées sur l'exemple CoCoME confortent nos propositions.
these17juin2011.pdf (4.53 Mo) Télécharger le fichier
tel-01146895 , version 1 (29-04-2015)
  • HAL Id : tel-01146895 , version 1
El-Habib Mohamed Messabihi. Contribution à la spécification et à la vérification des logiciels à base de composants : enrichissement du langage de données de Kmelia et vérication de contrats. Génie logiciel [cs.SE]. Université de Nantes, 2011. Français. ⟨NNT : ⟩. ⟨tel-01146895⟩
246 Consultations
481 Téléchargements
