Étude du transport turbulent dans les plasmas du tokamak Tore Supra : observation des écoulements perpendiculaires stationnaires et du mode acoustique géodésique - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2015
Study of the turbulent transport in the Tore Supra tokamak : observation of stationary perpendicular flows and of the geodesic acoustic mode
Alexandre Storelli
  • Fonction : Auteur
  • PersonId : 967802
Tokamaks are toroidal machines designed to magnetically confine plasma and to host reactions of nuclear fusion. Their performance is limited by turbulent transport, which precise mechanisms are not fully elucidated. Turbulent fluctuations cause the onset of macroscopic mean flows, in the direction perpendicular to both magnetic field and small radius, called zonal flows. Their shear is known to decrease both fluctuation level and transport. Diagnostics of Doppler backscattering have been installed on Tore Supra (CEA Cadarache). They could measure the perpendicular velocity of turbulent fluctuations in different zones of the plasma. First, it is shown that, on average, fluctuations flow twice as fast at the low field side of the machine than at its top. The difference, significantly higher than predicted by common models, is put in perspective with the properties of magnetic equilibrium and the behaviour of fluctuations. Then, variations of the velocity, due to the zonal flow branch called geodesic acoustic mode (GAM), are examined in a series of experiments where collisionality is varied. Those observations have been quantitatively compared with a gyrokinetic simulation with the code GYSELA, using the equilibrium profiles from the experiments. GAM frequency in experiments is lower than predicted, especially at low collisionalities. In addition, the instationarity of GAM has been characterized with the Hilbert-Huang transform. Burts of GAM oscillations have similar statistics between experiments and simulation and their duration could be related with the nonlinear interaction between the GAM and turbulence and with the continuum damping which is observed in the simulation.
Les tokamaks, machines toroïdales à confinement magnétique conçues pour porter un plasma aux conditions nécessaires à l'obtention de réactions de fusion, ont des performances limitées par le transport turbulent, dont les mécanismes ne sont pas tous élucidés. Les fluctuations turbulentes alimentent des écoulements macroscopiques, dits flots zonaux, dont le cisaillement réduit en retour le niveau de fluctuation. Des dispositifs de rétrodiffusion Doppler ont été installés sur Tore Supra (CEA Cadarache) et permettent de mesurer la vitesse perpendiculaire des fluctuations. Premièrement, il est montré que la vitesse moyenne est près de deux fois supérieure du côté externe du plasma que dans sa partie supérieure, au-delà des prédictions conventionnelles. Ces asymétries sont mises en perspective avec certains aspects de l'équilibre magnétique et des caractéristiques des fluctuations. Puis, les oscillations de la vitesse, attribuées à la branche des flots zonaux dite mode géodésique acoustique (GAM), ont été caractérisées dans des expériences où la collisionalité varie. Elles sont comparées aux prédictions théoriques et aux résultats d'une simulation avec le code gyrocinétique GYSELA, utilisant les profils expérimentaux d'équilibre. La fréquence du GAM dans l'expérience est plus faible que prédit, en particulier aux plus basses collisionalités. Les variations de son intensité, détectées avec la transformée de Hilbert-Huang, montrent des bouffées d'oscillations de distributions analogues entre expérience et simulation, et dont la durée pourrait être liée à son interaction non-linéaire avec la turbulence ainsi qu'au phénomène d'amortissement de continuum observé dans la simulation.
150624merge.pdf (13.03 Mo) Télécharger le fichier
tel-01167913 , version 1 (25-06-2015)
tel-01167913 , version 2 (06-07-2015)
Paternité - Partage selon les Conditions Initiales
  • HAL Id : tel-01167913 , version 1
Alexandre Storelli. Étude du transport turbulent dans les plasmas du tokamak Tore Supra : observation des écoulements perpendiculaires stationnaires et du mode acoustique géodésique. Physique des plasmas [physics.plasm-ph]. École Polytechnique, 2015. Français. ⟨NNT : ⟩. ⟨tel-01167913v1⟩
388 Consultations
2052 Téléchargements
