Functions and signaling of Epac protein in cardiac hypertrophy
Rôles et mécanismes d’action de la protéine Epac dans l’hypertrophie cardiaque
Catecholamines regulate cardiac function by stimulating β-adrenergic receptors (β-AR), leading to cAMP production and activation of a multiplicity of signaling pathways. Epac proteins are exchange factors for small G proteins which are directly activated by cAMP. Given the importance of the β-adrenergic pathway in cardiac physiopathology, it becomes essential to characterize functions of Epac protein in myocardium. In a first part, this study shows that H-Ras and Rap2B GTPases are involved in Epac-induced neonatal rat cardiac myocytes hypertrophy. Epac induces activation of the PLC/IP3/Ca2+ pathway which is necessary for H-Ras activation. At the transcriptional level, Epac causes HDAC4 nuclear export leading to activation of a hypertrophic gene program. In a second part, this study reveals implication of Epac1 in cardiac hypertrophy in vivo. Deletion of Epac1 in mice protects from cardiac remodeling induced by chronic isoproterenol infusion and enhances cardiac function. Cardiac specific overexpression of Epac1 in mice induces cardiac myocytes hypertrophy. Interestingly, β-AR/Epac1 pathway triggers ubiquitinated proteins accumulation and activation of autophagy both in vitro and in vivo. By eliminating aggregates and by counteracting hypertrophic effects of Epac, autophagy protects from deleterious effects of the β-AR/Epac pathway. These results open news insights into the treatment of cardiac hypertrophy and heart failure.
Les catécholamines induisent la synthèse d’AMPc par une stimulation des récepteurs β-adrénergiques et contrôlent ainsi la fonction cardiaque en activant une pléiade de voies de signalisation intracellulaires. Les protéines Epac sont des facteurs d’échange pour les petites protéines G et sont directement activés par l’AMPc. Devant l’importance de la voie β-adrénergique dans la physiopathologie cardiaque et dans le but de mieux comprendre la régulation des processus cellulaires dépendants de l’AMPc dans le cœur, il apparaît essentiel de caractériser le rôle des facteurs d’échange Epac dans le myocarde. Dans une première partie, cette étude démontre que les effets de Epac sur l’hypertrophie des cardiomyocytes ventriculaires de rats nouveaux nés requièrent les GTPases H-Ras et Rap2B. Epac active la voie PLC/IP3/Ca2+ qui est nécessaire pour l’activation de H-Ras. Au niveau transcriptionnel, Epac induit l’export nucléaire de HDAC4 permettant l’activation d’un programme génique d’hypertrophie. Dans une deuxième partie, cette étude révèle l’implication de Epac1 dans l’hypertrophie des cardiomyocytes in vivo, chez la souris. La délétion de Epac1 protège du remodelage cardiaque induit par l’activation prolongée des récepteurs β-adrénergiques et améliore la fonction cardiaque. La surexpression de Epac1 spécifiquement dans le myocarde entraîne une hypertrophie des cardiomyocytes. Par ailleurs, la voie β-AR/Epac1 induit l’accumulation de protéines ubiquitinylées et provoque l’activation du processus d’autophagie in vitro et in vivo. L’autophagie protège des effets délétères de la voie β-adrénergique/Epac en participant à l’élimination des agrégats protéiques et en contrant les effets hypertrophiques de Epac1. Ces résultats ouvrent de nouvelles perspectives pour le traitement de l’hypertrophie et de l’insuffisance cardiaque.
