Design of a radio direction finder for search and rescue operations : estimation, sonification, and virtual prototyping - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2015
Navigation guidée par sonification des signaux GSM dans un contexte de secours
This research investigates the design of a radio Direction Finder (DF) for rescue operation using victims' cellphone as localization beacons. The conception is focused on an audio interface, using sound to progressively guide rescuers towards their target. The thesis' ambition is to exploit the natural mechanisms of human hearing to improve the global performance of the search process rather than to develop new Direction-Of-Arrival (DOA) estimation techniques.Classical DOA estimation techniques are introduced along with a range of tools to assess their efficiency. Based on these tools, a case study is proposed regarding the performance that might be expected from a lightweight DF design tailored to portable operation. It is shown that the performance of high-resolution techniques usually implemented for DOA estimation are seriously impacted by any size-constraint applied on the DF, particularly in multi-path propagation conditions.Subsequently, a review of interactive parameter mapping sonification is proposed. Various sonification paradigms are designed and assessed regarding their capacity to convey information related to different levels of DF outputs. Listening tests are conducted suggesting that trained subjects are capable of monitoring multiple audio streams and gather information from complex sounds. Said tests also indicate the need for a DF sonification that perceptively orders the presented information, for beginners to be able to effortlessly focus on the most important data only. Careful attention is given to sound aesthetic and how it impacts operators' acceptance and trust in the DF, particularly regarding the perception of measurement noise during the navigation.Finally, a virtual prototype is implemented that recreates DF-based navigation in a virtual environment to evaluate the proposed sonification mappings. In the meantime, a physical prototype is developed to assess the ecological validity of the virtual evaluations. Said prototype exploits a software defined radio architecture for rapid iteration through design implementations. The overall performance evaluation study is conducted in consultation with rescue services representatives and compared with their current search solutions.It is shown that, in this context, simple DF designs based on the parallel sonification of the output signal of several antennas may produce navigation performance comparable to these of more complex designs based on high-resolution methods. As the task objective is to progressively localize a target, the system's cornerstone appears to be the robustness and consistency of its estimations rather than its punctual accuracy. Involving operators in the estimation allows avoiding critical situations where one feels helpless when faced with an autonomous system producing non-sensical estimations. Virtual prototyping proved to be a sensible and efficient method to support this study, allowing for fast iterations through sonifications and DF designs implementations.
Cette thèse étudie le design et la conception d’un Goniomètre Radio Fréquence (GRF) visant à assister les services de secours à la personne (e.g. équipes de sauvetage déblaiement), exploitant les téléphones des victimes à retrouver comme des balises de détresse radio. La conception est focalisée sur une interface audio, utilisant le son pour guider progressivement les sauveteurs vers la victime. L’ambition de la thèse est d’exploiter les mécanismes naturels propres à l’audition humaine pour améliorer les performances générales du processus de recherche plutôt que de développer de nouvelles techniques d’Estimation de Direction de Source (EDS).Les techniques d’EDS classiques sont tout d’abord exposées, ainsi qu’une série d’outils permettant d’en évaluer les performances. Basée sur ces outils, une étude de cas est proposée visant à évaluer les performances attendues d’un GRF portable, adapté aux conditions d’emploi nominales envisagées. Il est montré que les performances des techniques dites « à haute résolution » généralement utilisées pour l’EDS sont sérieusement amoindries lorsqu’une contrainte de taille/poids maximum est imposée sur le réseau d’antennes associé au GRF, particulièrement en présence de multi-trajets de propagation entre le téléphone ciblé et le tableau d’antenne.Par la suite, une étude bibliographique concernant la sonification par encodage de paramètres (Parameter Mapping Sonification) est proposée. Plusieurs paradigmes de sonification sont considérés et évalués en rapport à leur capacité à transmettre une information issue de différents designs de GRF envisagés. Des tests d’écoute sont menés, suggérant qu’après une courte phase d’entrainement les sujets sont capables d’analyser plusieurs flux audio en parallèle ainsi que d’interpréter des informations de haut niveau encodées dans des flux sonores complexes. Lesdits tests ont permis de souligner le besoin d’une sonification du GRF basée sur une hiérarchie perceptive de l’information présentée, permettant aux débutants de focaliser leur attention sans efforts et uniquement sur les données les plus importantes. Une attention particulière est portée à l’ergonomie de l’interface sonore et à son impact sur l’acceptation et la confiance de l’opérateur vis-à-vis du GRF (e.g. en ce qui concerne la perception du bruit de mesure pendant l’utilisation du GRF pendant la navigation).Finalement, un prototype virtuel est proposé, simulant une navigation basée sur le GRF dans un environnement virtuel pour en évaluer les performances (e.g. paradigmes de sonification proposés plus haut). En parallèle, un prototype physique est assemblé afin d’évaluer la validité écologique du prototype virtuel. Le prototype physique est basé sur une architecture radio logicielle, permettant d’accélérer les phases de développement entre les différentes versions du design de GRF étudiées. L’ensemble des études engageant les prototypes virtuels et physiques sont menées en collaboration avec des professionnels des opérations de recherche à la personne. Les performances des designs de GRF proposés sont par la suite comparées à celles des solutions de recherche existantes (géo-stéréophone, équipes cynotechniques, etc.).Il est montré que, dans le contexte envisagé, un simple GRF basé sur la sonification en parallèle des signaux provenant de plusieurs antennes directionnelles peut offrir des performances de navigations comparables à celles résultantes de designs plus complexes basés sur des méthodes à haute résolution. Puisque l’objectif de la tâche est de progressivement localiser une cible, la pierre angulaire du système semble être la robustesse et la consistance de ses estimations plutôt que sa précision ponctuelle. Impliquer l’utilisateur dans le processus d’estimation permet d’éviter des situations critiques où ledit utilisateur se sentirait impuissant face à un système autonome (boîte noire) produisant des informations qui lui semblent incohérentes.
these_archivage_3160048o.pdf (26.64 Mo) Télécharger le fichier
tel-01192598 , version 1 (03-09-2015)
  • HAL Id : tel-01192598 , version 1
David Poirier-Quinot. Design of a radio direction finder for search and rescue operations : estimation, sonification, and virtual prototyping. Acoustics [physics.class-ph]. Université Pierre et Marie Curie - Paris VI, 2015. English. ⟨NNT : 2015PA066138⟩. ⟨tel-01192598⟩
526 Consultations
2170 Téléchargements
