Formation et devenir de l’aérosol organique secondaire : étude expérimentale de formation d’organosulfates à l’interface gaz-particules - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2014
Formation and aging of secondary organic aerosols : experimental study of organosulfate formation at the gas-particle interface
This work deals with the formation and aging processes of secondary organic aerosol (SOA). More precisely, the objective was to document organosulfate formation, recently identified in ambient aerosol. Volatile organic compounds (VOCs) such as monoterpenes have been recognized as potentially important precursors of organosulfates in the atmosphere. However, organosulfate formation is not yet well understood. Reliable chemical mechanisms can only be accessible when studying individual reactions at the molecular level. In this work, organosulfate formation was studied for the reactions of α-pinene and associated oxidized species (α-pinene oxide, myrtenal, isopinocampheol and pinanediol) with acidified ammonium sulfate particles. On-line quantification of VOCs was carried out using proton-transfer-reaction mass spectrometry. Identification of products in the particulate phase has been performed using liquid chromatography coupled with tandem mass spectrometry. Experiments from quasi-static reactor and atmospheric simulation chamber experiments are compared and discussed, allowing to propose chemical mechanisms explaining organosulfate formation for the heterogeneous reactions of interest.
Ce travail a eu pour objectif d’améliorer notre compréhension des processus de formation et d’évolution des aérosols organiques secondaires (AOS) en étudiant les réactions susceptibles d’expliquer la présence d’espèces « mixtes » organosoufrées observées récemment dans l’aérosol atmosphérique. Les composés organiques volatils et en particulier les monoterpènes ont été identifiés comme étant des précurseurs potentiellement importants d’organosulfates dans l’atmosphère. Cependant, les mécanismes de formation de ces derniers ne sont pas encore bien compris. Seule une étude au niveau moléculaire et ciblée sur une réaction multiphasique unique, peut donner accès à des mécanismes réactionnels détaillés. Ainsi, les réactions entre l’α-pinène et quatre produits d’oxydation associés (α-pinène oxyde, myrténal, isopinocamphéol et pinanediol), avec des particules modèles de sulfate d’ammonium ont été étudiées individuellement dans le but de documenter la formation d’organosulfates. L’effet de l’humidité relative et celui de l’acidité des particules sur ces réactions ont été étudiés. La quantification en ligne des composés organiques volatils a été effectuée à l’aide d’un spectromètre de masse à transfert protonique. L’identification des structures moléculaires des organosulfates, formés en phase particulaire, a été effectuée par chromatographie liquide couplée à la spectrométrie de masse en tandem. Deux approches complémentaires, impliquant des expériences en réacteur quasi-statique et en chambre de simulation atmosphérique, ont permis de mettre en évidence la formation d’organosulfates mais également de proposer des mécanismes réactionnels pour l’ensemble des composés oxydés étudiés.
DUPORTE_GEOFFROY_2014.pdf (8.15 Mo) Télécharger le fichier
tel-01193131 , version 1 (04-09-2015)
  • HAL Id : tel-01193131 , version 1
Geoffroy Duporte. Formation et devenir de l’aérosol organique secondaire : étude expérimentale de formation d’organosulfates à l’interface gaz-particules. Autre. Université de Bordeaux, 2014. Français. ⟨NNT : 2014BORD0262⟩. ⟨tel-01193131⟩
446 Consultations
744 Téléchargements
