Security analysis for pseudo-random number generators - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2015
Analyse de sécurité pour les générateurs de nombre pseudo-aléatoires
In cryptography, randomness plays an important role in multiple applications. It is required in fundamental tasks such as key generation and initialization vectors generation or in key exchange. The security of these cryptographic algorithms and protocols relies on a source of unbiased and uniform distributed random bits. Cryptography practitioners usually assume that parties have access to perfect randomness. However, quite often this assumption is not realizable in practice and random bits are generated by a Pseudo-Random Number Generator. When this is done, the security of the scheme depends of course in a crucial way on the quality of the (pseudo-)randomness generated. However, only few generators used in practice have been analyzed and therefore practitioners and end users cannot easily assess their real security level. We provide in this thesis security models for the assessment of pseudo-random number generators and we propose secure constructions. In particular, we propose a new definition of robustness and we extend it to capture memory attacks and side-channel attacks. On a practical side, we provide a security assessment of generators used in practice, embedded in system kernel (Linux /dev/random) and cryptographic libraries (OpenSSL and Java SecureRandom), and we prove that these generators contain potential vulnerabilities.
La génération d’aléa joue un rôle fondamental en cryptographie et en sécurité. Des nombres aléatoires sont nécessaires pour la production de clés cryptographiques ou de vecteurs d’initialisation et permettent également d’assurer que des protocoles d’échange de clé atteignent un niveau de sécurité satisfaisant. Dans la pratique, les bits aléatoires sont générés par un processus de génération de nombre dit pseudo-aléatoire, et dans ce cas, la sécurité finale du système dépend de manière cruciale de la qualité des bits produits par le générateur. Malgré cela, les générateurs utilisés en pratique ne disposent pas ou peu d’analyse de sécurité permettant aux utilisateurs de connaître exactement leur niveau de fiabilité. Nous fournissons dans cette thèse des modèles de sécurité pour cette analyse et nous proposons des constructions prouvées sûres et efficaces qui répondront à des besoins de sécurité forts. Nous proposons notamment une nouvelle notion de robustesse et nous étendons cette propriété afin d’adresser les attaques sur la mémoire et les attaques par canaux cachés. Sur le plan pratique, nous effectuons une analyse de sécurité des générateurs utilisés dans la pratique, fournis de manière native dans les systèmes d’exploitation (/dev/random sur Linux) et dans les librairies cryptographiques (OpenSSL ou Java SecureRandom) et nous montrons que ces générateurs contiennent des vulnérabilités potentielles.
Ruhault-2015-These.pdf (1.85 Mo) Télécharger le fichier
tel-01236602 , version 1 (03-12-2015)
tel-01236602 , version 2 (18-04-2018)
  • HAL Id : tel-01236602 , version 2
Sylvain Ruhault. Security analysis for pseudo-random number generators. Cryptography and Security [cs.CR]. Ecole normale supérieure - ENS PARIS, 2015. English. ⟨NNT : 2015ENSU0014⟩. ⟨tel-01236602v2⟩
873 Consultations
4526 Téléchargements
